15 years agoProblems with Verilog % Modulo and if-Statements
Hi all, I got a problem with a normally relatively straightforward piece of Verilog code representing some modulo arithmetics and an if-statement. In the code below, the modulo of the r...
15 years ago --- Quote Start --- By the way: What's the deal with the always blocks? Can I rely on the code being executed like e.g. in a C environment or does timing matter here? In other words: is it guaranteed that the code is properly executed sequentially? --- Quote End --- In a procedural block the commands are executed sequentially. Timing has no influence on this. If you use blocking assignments '=', (for example to assign a value to variable Y) and you use Y again to assigna a value to Z. Z is calculated using the new value of Y. If you use non blocking assignments '<=', (for example to assign a value to variable Y) and you use Y again to assigna a value to Z. Z is calculated using the value of Y before entering in the always statement. In this case Y is updated only when exiting from the always statement. Hope it helps. Better to read a Verilog book regarding these aspects.
