15 years agoProblems with Verilog % Modulo and if-Statements
Hi all, I got a problem with a normally relatively straightforward piece of Verilog code representing some modulo arithmetics and an if-statement. In the code below, the modulo of the r...
15 years agoIt is not tru that combinational block should not use always block.
In your case: --- Quote Start --- always @(iq,iStage) begin c <= (iq + 1'b1) % (1'b1<<(iStage)); end --- Quote End --- is a combinational block. It can also be written without the always statement as: --- Quote Start --- assign c = (iq + 1'b1) % (1'b1<<(iStage)); --- Quote End --- By the way, are you sure that shifting a 1 bit signal (1'b1) provides a signal with more than one bit? Maybe that, if iStage is a two bit signal the maximum shift is three positions, the command should be: --- Quote Start --- assign c = (iq + 1'b1) % (4'b0001<<(iStage)); --- Quote End --- Not sure about this however...
