15 years agoProblems with Verilog % Modulo and if-Statements
Hi all, I got a problem with a normally relatively straightforward piece of Verilog code representing some modulo arithmetics and an if-statement. In the code below, the modulo of the r...
15 years agoHi all,
thanks for you help and your comments on my code. I think the code again needs some review and definitely needs to be done from a point of view which is more "hardware". However, I do not fully understand what you mean by using combinational logic for doing the calculations. So here's as far as I understood you: 1) The Calculations of a, b, and c should NOT be done in an "always" block 2) The if-statement is then executed in an "always" block triggered by the clock What does that mean for me? How can I create the calculation outside of the always statement? Do I maybe even have to implement a module for each of the calculations? How do I correctly trigger all this stuff? By the way: What's the deal with the always blocks? Can I rely on the code being executed like e.g. in a C environment or does timing matter here? In other words: is it guaranteed that the code is properly executed sequentially? Thanks a lot! Jonas Lindmann
