Problems with configuring CycloneIV from EPCQ32A
Apologize for the delay in response.
-As you are saying that there is not JTAG interface, I assume you are using Passive serial scheme?
-The only issue I can think is that, if you have follow the device migration guidelines correctly. As you were migrating from EPCS16 to EPCQ32A. EPCQ32A is different, hence you need to make sure that you have follow the migration guidelines correctly.
-Can you provide the screenshot of configuration timing diagram? that have CONF_DONE, nSTATUS, DCLK,ASDATA, etc...
-Have you try using the EPCQ32? Previous reply you are mentioning to try with EPCQ32. How is it working?
Aiman
Hi, Aiman!
We are using Active serial scheme.
We've changed EPCQ32A to EPCQ32 and I can program it several times. FPGA configures normally after each power up. So, there is a difference between EPCQ32A and EPCQ32...
