17 years ago
Problems using command-line interface
I am fairly new to using Quartus. (using version 8.0) I have a project that Successfully compiles in the GUI. However, when I try to use quartus_map I get the following errors:
--- Quote Start ---
$ quartus_map fec_dsp_interface_pkg_top --source fec_dsp_interface_pkg_top.qpf --family=CYCLONEIII
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 8.0 Build 231 07/10/2008 Service Pack 1 SJ Full Version
Info: Copyright (C) 1991-2008 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Tue Jan 27 15:57:19 2009
Info: Command: quartus_map fec_dsp_interface_pkg_top --source=fec_dsp_interface_pkg_top.qpf --family=CYCLONEIII
Warning: Using design file fifo_controller.vhd, which is not specified as a design file for the current project, but contains definitions for 3 design units and 1 entities in project
Info: Found design unit 1: fifo_controller_pkg
Info: Found design unit 2: fifo_controller-behaviour
Info: Found entity 1: fifo_controller
Error (10481): VHDL Use Clause error at fifo_controller.vhd(93): design library "work" does not contain primary unit "dsp_register_pkg" File:
fifo_controller.vhd Line: 93
Error (10800): VHDL error at fifo_controller.vhd(93): selected name in use clause is not an expanded name File: fifo_controller.vhd Line: 93
Error (10481): VHDL Use Clause error at fifo_controller.vhd(94): design library "work" does not contain primary unit "dsp_status_register_pkg" File: fifo_controller.vhd Line: 94
Error (10800): VHDL error at fifo_controller.vhd(94): selected name in use clause is not an expanded name File: fifo_controller.vhd Line: 94
Error (10481): VHDL Use Clause error at fifo_controller.vhd(95): design library "work" does not contain primary unit "constants" File: fifo_controller.vhd Line: 95
Error (10800): VHDL error at fifo_controller.vhd(95): selected name in use clause is not an expanded name File: fifo_controller.vhd Line: 95
Error: Quartus II Analysis & Synthesis was unsuccessful. 6 errors, 1 warning
Error: Peak virtual memory: 173 megabytes
Error: Processing ended: Tue Jan 27 15:57:20 2009
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
--- Quote End ---
Any ideas would be appreciated as I am working to develop scripts around Quartus.
Thank you,
Tom
    Thank you, this seems to fix that. I was going verbatim from the Altera Command-Line Scripting documentation.
    Why are you using all those command line arguments? The qsf file (which the qpf points at) has all the settings that you need, just run
    quartus_map <projectfile.qpf>
    in your script, (minus the <>)
