17 years agoProblems using command-line interface
Hi, I am fairly new to using Quartus. (using version 8.0) I have a project that Successfully compiles in the GUI. However, when I try to use quartus_map I get the following errors: --- Qu...
17 years agoWhy are you using all those command line arguments? The qsf file (which the qpf points at) has all the settings that you need, just run
quartus_map <projectfile.qpf> in your script, (minus the <>)
