14 years agoProblem with Zip file
Hello guys, Good day. I have problem after download zip file into flash. I already download .sof file and zip file without any error. Just warnings appear. Should appear at LCD display is " We...
14 years ago --- Quote Start --- The mount point looks ok. Is your flash mapped at address 0x1400000, as you configured in the rozipfs? How do you write the zip to the flash? Are you sure 0x17fffff is the correct offset? --- Quote End --- Hi Daixiwen, The zip file is write into cfi_flash using flash programmer. Actually the mount point is the default setting after I enable the zipfile system (in BSP setting). How to know the right flash mapped address and offset value? Thanks for your cooperation and concern
