14 years agoProblem with Zip file
Hello guys, Good day. I have problem after download zip file into flash. I already download .sof file and zip file without any error. Just warnings appear. Should appear at LCD display is " We...
14 years agoI'm not sure, I don't use the IDE myself... Can't you step in the software anyway? It looks like the options are active and the breakpoint is reached.
In the BSP settings when you enabled the zip filesystem, did you put the correct mointpoint? Did you check that you disabled compression when creating the zip file? The zip filesystem doesn't support compression.
