15 years agoProblem with programming the M25P32 using a Jam file
Hi all, I have a rather difficult problem. I need to program a serial config device (that is used to configure an EP3C55) using third party software (Goepel CASCON, not Quartus II). The only wa...
11 years ago --- Quote Start --- I tried this a year or so ago and as I remember I got a "EPCS32" choice in the Configuration device box of the Convert programming files menu. I can not get that choice now. I have tried on QUARTUS 9.1 and 13.1 --- Quote End --- Have you recently upgraded to a newer version of Quartus? When Quartus installs a new version, it will create an entirely new folder, so you will have to find the new directory for the version that you are using and add a quartus.ini file in the bin directory there too. Additionally, if you are using a 64-bit operating system then the .ini file should be placed in the bin64 folder. To be consistent, keep a copy of the quartus.ini file in each bin folder of each version.
