15 years agoProblem with programming the M25P32 using a Jam file
Hi all, I have a rather difficult problem. I need to program a serial config device (that is used to configure an EP3C55) using third party software (Goepel CASCON, not Quartus II). The only wa...
11 years ago --- Quote Start --- Has anyone been able to get this to work? --- Quote End --- Hi Randy The solution that I proposed above works. I have tested on all Quartus version 9 to 11 without a problem. It is possible that it no longer works on the later versions, but with a cursory check it appears to be working on v13 too.
