15 years agoProblem with programming the M25P32 using a Jam file
Hi all, I have a rather difficult problem. I need to program a serial config device (that is used to configure an EP3C55) using third party software (Goepel CASCON, not Quartus II). The only wa...
15 years agoHello!
Problem solved thanks to Altera support. Carry out these steps in order to create a jam file that is compatible with the M25P32. 1. In your Quartus/bin directory create a file called “quartus.ini” 2. In the quartus.ini file write: “pgm_allow_epcs32=on”. This allows you to create jic files that will program an EPCS32 device, even though they don’t really exist. 3. Create a .jic file that uses the epcs32 device. 4. From the jic file you can then create a jam file in the programmer that has no conflicts with the silicon id of the M25P32. Hope this helps someone else! Regards.
