17 years agoProblem with PLL in EP1C12 device
Hello everyone, long time no see =] Recently I've built my own evaluation board with EP1C12 Cyclone device (yes, it's an old one, but I obtained it for free). The board is working, I can config...
17 years agoI can't see, if the PLL Megafunction is configured correctly, but the clock divider is hold in reset by this line, so no output can be expected.
div_rst <= PLL_lock and nrst; P.S.: O.K., I see it's actually ndiv_rst, it should work then. The division factor is 21 in your design, resulting in 4.76 MHz output clock with 100 MHz input. Do you see a locked state?
