8 years agoProblem with Max 10 I've never seen before
I have an issue with a MAX 10 design. I've never seen this problem before and I am baffled by it. I have down loaded the FPGA image, which includes a NIOS, and user application code to the internal...
8 years agoHi,
Hope this may help you. FPGA board is powered by the system/unite right, can you check the power supply requirements and its interface between the system and FPGA board once. If possible issolate the System power which is used to power the FPGA board. And power the FPGA board external and use other system interface and check. Check the de-caps or bulk-cap used in power lines(from FPGA board to the System board). 1. Avoid doing hot plugin and plug out? 2. Make sure to erase the flash location before you perform a program (write) operation. Let me know if this has helped resolve the issue. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
