11 years agoproblem with JTAG configuration cyclone III
Hi, I am using cyclone III, epc3c10k. I have a problem of configuration from JTAG using usb blaster. Where I try to programming from quartus the JTAG can’t work. I connected the ncomfig, ...
11 years agoI don't believe the lack of connection to the exposed pad will prevent a correctly powered device from being discoverable via JTAG.
I do base this on experience and a board we successfully had working, despite the lack of thermal pad on the PCB. This was using a Cyclone IV device. It could be that the thermal pad is connected differently internally to that of Cyclone III devices. However, I doubt it. Some of the voltages you're reporting seem a little strange too based on how you are powering the device. Unfortunately, I think this is more likely to be damage to the device. Sorry. Cheers, Alex
