14 years agoProblem with Gigabit Ethernet Clocks
Hi, I am working in a design that includes a propietary MAC layer to the PHY Marvell Ethernet chip, using RGMII interface. The FPGA that I used to the design is a ARRIA GX II 260. I have define...
14 years agoYep, always check if clocks are defined correctly, then the possibility to run the design even with timing warnings rises alot :-)
