14 years agoProblem with Gigabit Ethernet Clocks
Hi, I am working in a design that includes a propietary MAC layer to the PHY Marvell Ethernet chip, using RGMII interface. The FPGA that I used to the design is a ARRIA GX II 260. I have define...
14 years agoYou can also check the warnings when you run Timequest, if some of your lines in the SDC script couldn't be executed for some reason, it will add a warning. Both the inputs and the outputs should be constrained.
