8 years agoProblem with FIR II core
Hello, I am trying to use 11 taps symmetrical FIR using the IP Catalog in Quartus 14.1 My data are in signed Q.15 format with sampling rate 288MHz. I get the data in packets of 4 samples (...
8 years ago --- Quote Start --- If I have to ask different way. What do you think is the maximum clock rate I can clock my 11 taps symmetric FIR from the IP core if enough resources on Stratix IV silicon? --- Quote End --- In fpga jargon you are asking for "fmax". That is implementation issue. For a good design you can well get 300MHz in your device
