8 years agoProblem with FIR II core
Hello, I am trying to use 11 taps symmetrical FIR using the IP Catalog in Quartus 14.1 My data are in signed Q.15 format with sampling rate 288MHz. I get the data in packets of 4 samples (...
8 years ago --- Quote Start --- Thank you kaz! I'll try to derive 288MHz As a separate question. Do you think that there is simple solution of what i want with IP Catalog FIR II core in 72MHz domain? Thanks Dimitar --- Quote End --- The short answer is no you can use two parallel sections as even odd samples @ 144. You will need four sub-filters, not worth it and has to be done by hand not fir compiler. After all I assume your output may have to be one stream @ 288
