8 years agoProblem with FIR II core
Hello, I am trying to use 11 taps symmetrical FIR using the IP Catalog in Quartus 14.1 My data are in signed Q.15 format with sampling rate 288MHz. I get the data in packets of 4 samples (...
8 years ago --- Quote Start --- Hi Kaz, I don't understand what you mean by "path". Probably we still misunderstood. Let me try again: 1. I have single 16 bit, 288Hz data stream (it represents one analog signal acquired with 16bit ADC, clocked with 288MHz) 2. I want to filter this signal (in digital domain) using symmetrical FIR with 11 coefficients 3. My current system is implement such a way that I get four 16 bit samples from the stream at once. (This means that I get 4 samples each 72 MHz) How would you approach this problem in Quartus ? Regards Dimitar --- Quote End --- ok your stream is 16 bits @ 288Msps but implemented as 4 parallel sections @ 72MHz All you have to do is: convert the 4 section to 288 speed (serialise the 4 sections and pass it to filter(one channel @ 288 clock rate and 288 sample rate)
