16 years agoproblem with cyclone III and jtag
I would like to put a very serious discussion about using jtag with cyclone III. has cyclone3 less electrical tolerance compared to other FPGA's?????? . we are building a custom board. and t...
16 years agoIt should be good. Just check that the 74LVC541 is powered by a 2.5V supply (or if you power it with 3.3V, put also 3.3V on the Jtag pin 4) and that the pull ups/down are between the JTAG connector and the buffer, and not between the buffer and the FPGA.
