16 years agoproblem with cyclone III and jtag
I would like to put a very serious discussion about using jtag with cyclone III. has cyclone3 less electrical tolerance compared to other FPGA's?????? . we are building a custom board. and t...
16 years ago --- Quote Start --- You are right. They don't put the clamping diodes on figure 9-24, and instead recommend to use vcca (2.5V) as the jtag i/o power supply instead of the bank 3.0/3.3V supply. It works too, but I find the clamping diodes safer. --- Quote End --- Is it a problem to use VCCA 2.5V AND put something like the SN74LVC541 buffer in between the FPGA and JTAG connection? Do you advise that TCK, TMS, TDI, and TDO all go through the buffer.
