17 years agoProblem with "constant driver error"
Hello, I am trying to put together a simple one shot counter that gets trigered once every time an input signal (Gate) the counter just counts to some preloaded value and then just stops counting ...
17 years agoThank you both; pletz and FvM for your help, I have slightly modified pletz code and got it to work exactly the way I wanted. Lookin both of your sugestions has given me a little more insight as to what I need to do. I was actually trying to make a simple variable pulse generator as part of a learning project for both the quartus tool and the verilog hdl.
You are right FvM, regarding the Gate signal it has to be synchronized with the clock and the gate time must always be >> than the one shot pulse in order for thing to work correctly.
