14 years agoproblem with a multiprocessor system
Hello i have built a system with 4 processors, each working independantly of others (an atomous system). When i launch 3 processors at the same time in the nios IDE the system works well. But w...
14 years agoThe problem may be in using the SDRAM memory. The SDRAM write command does not enable to allocate códido at a different address in SDRAM! Nevertheless, when you use the Flash memory is possible to specify where each part of code will be write in command. Check it!
