12 years agoProblem when download FPGA SRAM OBJECTIVE FILE.
https://www.alteraforum.com/forum/attachment.php?attachmentid=8003 when use Quartus II software and select Tools > Programmer to download .sof instance file . coming: Info (209060): Started P...
12 years ago --- Quote Start --- https://www.alteraforum.com/forum/attachment.php?attachmentid=8003 when use Quartus II software and select Tools > Programmer to download .sof instance file . coming: Info (209060): Started Programmer operation at Wed Nov 06 17:58:42 2013 Error (209031): Device chain in Chain Description File does not match physical device chain -- expected 1 device(s) but found 2 device(s). Error (209012): Operation failed Info (209061): Ended Programmer operation at Wed Nov 06 17:58:42 2013 the device is auto detected . where is the problem? --- Quote End --- As I see you are using Arrow SocKIT dev. board. - Configure FPGA board properly ! (SOCVHPS is missed from your actually detected chain) - Reset FPGA (try warm, hard, and FPGA reset) - Hardware Setup -> CV_SOCKIT - Auto detect chain - Change file -> browse for .sof (which contains the same FPGA device as 5CSXFC6D6) - Finally, Program FPGA alternatively, try Quartus -> Tools -> JTAG chain debugger -> Test JTAG chain Altera help: http://quartushelp.altera.com/13.1/mergedprojects/msgs/msgs/epgme_chain_length_mismatch.htm Regards, Zs.V.
