17 years agoProblem when configuring Stratix II Board
I can upload the factory program fine to the Stratix II board but when I try to upload the program I had made I think it encounters an error. The program complied fine. Both of the red leds come on and also the fan stops. The enthernet chip also gets hot even though I am not using it and do not have anything going to it pins. Thank you in advance for any help.2 Replies
Yes. In the Device settings you need to select the option to set unused pins to tri-state. If this is not the case, you're lucky if you haven't damaged something.
Jake - Altera_Forum
make sure your project has unused io tri-stated and not driven to ground, unfortunately the later is the default.
--dalon
