17 years agoProblem when configuring Stratix II Board
Hi, I can upload the factory program fine to the Stratix II board but when I try to upload the program I had made I think it encounters an error. The program complied fine. Both of the re...
17 years agoYes. In the Device settings you need to select the option to set unused pins to tri-state. If this is not the case, you're lucky if you haven't damaged something.
Jake
