14 years agoProblem using ISSI's SRAM on Stratix IV GX
Hello everyone. Anyone had luck using the SSRAM provided on a Stratix IV GX Dev Kit (EP4SGX230KF40C2ES)? I think there is a huge lack of information by Altera by using this SSRAM module, o...
14 years ago --- Quote Start --- -Data Bus test passed -Address bus test failed at address 0x200004 --- Quote End --- It looks like the test software is able to write different values to the first address, but not the second one. Can you check in the pin planner that the fsm_a[20..0] ports are assigned to the correct FPGA pins? Verify using the board's schematic. (the user documentation can be wrong sometimes)
