15 years agoProblem using DDR3 bottom port with StratixIV EP4SGX230KF40C2
Hi, I'm trying to introduce with SOPC_BUILDER the DDR3 64 bits in my design, that also includes NIOS 2 and flash. Analysis and synthesis go well, but when I try to run the hello_world test on...
15 years agoWhich Quartus version are you using?
I see you have 2 uart(s) in a SOPC. As far as I recall, there was an issue that the SBT will mess up with multiple connection points in Q10.0. It seems like OK in 10.1. If you remove one of the uart, it may work. https://www.alteraforum.com/forum/attachment.php?attachmentid=3641
