JStag
8 years agoProblem selecting image to run using configsel pin on Max10.
I have been working with the simple LED Binary and KnightRider example for the I2C RSU slave example on the 10m08sae144eval board. I have built each project using dual compressed image setting and th...
AnandRaj_S_Intel
8 years agoHi,
- Check the Option/Boot Info and the ICB setting dialog box. The ICB setting dialog box allows you to set the following:
- User I/Os weak pull up during configuration.
- Configure device from CFM0 only.
- Note: When you disable this feature, the device will always load the configuration image 0 without sampling the physical CONFIG_SEL pin. After successfully load the configuration image 0, you can switch between configuration image using the config_sel_overwrite bit of the input register. Refer to related information for details about Altera Dual Configuration IP core input register.
For more information refer below link.
Anand Raj Shankar
