11 years agoproblem programming old cpld (epm7032)
HI, I have thi problem: - old design and HW based on epm7032 (5V) - epm7032 pof file generted with maxplus vers. 9 (I hve the sources) - the design use the JTAG pin (TMS, TCK, TDI, TDO..) as...
ak6dn
4 years agoBad idea. Never use the JTAG pins as normal I/O. You will regret it.
If you do use them as normal I/O, you can only program a new blank device ONCE via JTAG USB Blaster.
After the first programming, you must use a third party device programmer that is non-JTAG to reprogram the device.
I suspect the device you are trying to program is not blank, but has been programmed before so that the JTAG interface is disabled.
