17 years agoProblem on writting
Hi guys, I'm tryining to write on my own controller that communicates through avalon bus.
I'm debuggin my small program from NIOS II EDS and when the line is executed IOWR(DUMMY_0_BASE,0,Tmp1); this errors appears : assertion "m_state == STATE_DEBUG" failed: file "nios2debug.cpp", line 286 C:\altera\81\nios2eds\bin\nios2-download: line 594: 5444 Aborted (core dumped) nios2-gdb-server --instance 0 --tcpport auto --write-pid Debug/n ios2-download.pid Anyone knows why this is occuring ? ( The address it's correctly on system.h file) Thank you for any help :-)4 Replies
--- Quote Start --- this is the error what i get Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x20000088: verified Initializing CPU cache (if present) OK Downloading 10000120 ( 0%) Downloaded 42KB in 0.5s (84.0KB/s) Verifying 10000120 ( 0%) Verified OK Starting processor at address 0x100002B4 assertion "m_state == STATE_DEBUG" failed: file "nios2debug.cpp", line 563 /cygdrive/c/altera/10.0sp1/nios2eds/bin/nios2-download: line 601: 18396 Hangup nios2-gdb-server --cable 'USB-Blaster on localhost [USB-0]' --device 1 --instance 0 --sidp 0x20000088 --id 0x0 --timestamp 1307681075 --go --tcpport none --write-pid /cygdrive/d/BMSCE/MMCAS/10thJune2011/DDR3/software/hello_ddr3/nios2-download.pid d:/BMSCE/MMCAS/10thJune2011/DDR3/software/hello_ddr3/hello_ddr3.elf.srec please suggest me the solution Hi, What changes should be done to meet DDR3 Timing requirements if I am migrating my project from use of EP2AGX125EF35c4 as FPGA to EP2AGX125EF35i5 as FPGA ? --- Quote End --- Has this error been solved? Could you pls share how you solved it? - Altera_Forum
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x20000088: verified Initializing CPU cache (if present) OK Downloading 10000120 ( 0%) Downloaded 42KB in 0.5s (84.0KB/s) Verifying 10000120 ( 0%) Verified OK Starting processor at address 0x100002B4 assertion "m_state == STATE_DEBUG" failed: file "nios2debug.cpp", line 563 /cygdrive/c/altera/10.0sp1/nios2eds/bin/nios2-download: line 601: 18396 Hangup nios2-gdb-server --cable 'USB-Blaster on localhost [USB-0]' --device 1 --instance 0 --sidp 0x20000088 --id 0x0 --timestamp 1307681075 --go --tcpport none --write-pid /cygdrive/d/BMSCE/MMCAS/10thJune2011/DDR3/software/hello_ddr3/nios2-download.pid d:/BMSCE/MMCAS/10thJune2011/DDR3/software/hello_ddr3/hello_ddr3.elf.srec please suggest me the solution Hi, What changes should be done to meet DDR3 Timing requirements if I am migrating my project from use of EP2AGX125EF35c4 as FPGA to EP2AGX125EF35i5 as FPGA ? http://www.alteraforum.com/forum//proweb/buttons/quote.gif (http://www.alteraforum.com/forum/newreply.php?do=newreply&p=121727) - Altera_Forum
Hi Jake, thank you for try help me.
I've check the system.h file and all seems correct. This is a pic from my SOPC http://img36.imageshack.us/img36/8141/sopc.jpg - Altera_Forum
Hmmm. Check your system.h file and make sure that the macro "DUMMY_0_BASE" matches the based address of your component in SoPC builder. Actually can you post a screenshot of your SoPC system?
Jake
