15 years agoProblem in running NIOS II Software Project on Altera
I keep getting this error while trying to run software projects built in NIOS II IDE using cable "usb-blaster [usb-0]", device 1, instance 0x00 pausing target processor: not responding. res...
15 years agoFinally Success with Hello-World NIOS II Software Project with LEDs and Switches
Had to make these changes. 1. Created a new .sof file all over from scratch 2. Instantiated the new processor in schematic file and connected the input and output ports 3. Made proper pin assignments for input and output ports - Didn't have to consider timing requirements - Had to map the reset button to a toggle switch and kept in in high logic tut_sopc_introduction_vhdl.pdf had been a great help . Thank you All for supporting !!!
