15 years agoProblem in running NIOS II Software Project on Altera
I keep getting this error while trying to run software projects built in NIOS II IDE using cable "usb-blaster [usb-0]", device 1, instance 0x00 pausing target processor: not responding. res...
15 years agoHey jayesh thanks for the support
I re-chose the device family , synthesized and then loaded into the board. I think i made a little development from the previous error. But still it shows new errors Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x021208B8: verified Initializing CPU cache (if present) OK Downloading 02100020 ( 0%) Downloading 04000000 ( 0%) Downloading 04010000 (88%) Downloaded 73KB in 1.2s (60.8KB/s) Verifying 02100020 ( 0%) Verifying 04000000 ( 0%) Verify failed between address 0x4000000 and 0x400FFFF Leaving target processor paused What else can i do ? Thanks
