15 years agoProblem in running NIOS II Software Project on Altera
I keep getting this error while trying to run software projects built in NIOS II IDE using cable "usb-blaster [usb-0]", device 1, instance 0x00 pausing target processor: not responding. res...
15 years agoAfter the device is programmed with time limited .sof file it showed a dialog box such as
OpenCore Plus Status Click Cancel to stop using OpenCore Plus IP. Time Reamaining unlimited Cancel i never closed this window but i still get the same error Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused Could there be anymore reason why it is not responding. Thanks
