15 years agoProblem in programming C II using ASP or JTAG
Can I configure C II FPGA without CPLD? I designed a board that uses C II EP2C5t144 and used ONLY a config chip called EPCS1NI8. I attached the schematic here for that portion. Can you hel...
15 years agoI have the MSEL0 and MSEL1 connected to the GND.
Is that correct for the ASP mode? I was surprised this morning that it did work, I mean I was able to upload using the ASP connector. Would that be because I left the board for 24 hours not used. That indicates to me (with a beginner knowledge) that it might be the FLUX residue, wasn't dry enough yesterday, and today got dry!! I really need to know why that happen. What do you think?
