11 years agoproblem in interfacing
Hi all, can any one suggest me how to interface altera cyclone 3 fpga starter kit( EP3C25F324 ) and ti daughter card ( SDALTEVK/NOPB ). i have both boards. when i see both schematic diagram the...
11 years agoQuartus assumes the single ended signal is going to cause interference on the differential signal because it's too close.
Add an 'io_maximum_toggle_rate "0mhz"' attribute to any non-differential signals in that bank. Do this as follows: In the 'Pin Planner', find the relevant signal - 'TX2_SDA'. In the 'Toggle Rate' column, enter 0 (zero). Do this for any non-differential signal in the same bank as 'tof_n'. If you can't see the 'Toggle Rate' column, right click anywhere in the column headings and select 'Customise Columns...', find 'Toggle Rate' in the 'Available columns:' box and add it to the visible columns. The JTAG signals (TMS, TDO etc.) are reserved pins - you don't need to assign them. I don't understand what you mean by the 'ek' signal. Cheers, Alex
