14 years agoProblem compiling in buildserver
Currently I have version 9.1 sp2 of nios and quartus installed. I am trying to build my project automatically with a batch script. I tried the solution described in "how to execute nios ii command shell commands from a *.bat file" (I may not post links) which works if I run the batch script directly from explorer (with a double click). Now, when I try to do this in any other environment such as a buildserver (team city) or final builder then nothing happens. Nios II Command Shell.bat is started, but the "make" command is not executed through cygwin. I know from my colleages that this idea does work in nios version 11. But I dont know if upgrading our project is feasable at the moment. Does any one have a solution for my problem?1 Reply
I fixed it.
In Nios II Command Shell.bat I changed to @ "%QUARTUS_ROOTDIR%\bin\cygwin\bin\bash.exe" -c "%2/do_some_awesome_magic_like_nios_version_11.sh %1 %2 %3 %4" And do_some_awesome_magic_like_nios_version_11.sh contains: # !/bin/bash source $1/nios2_sdk_shell_bashrc exec $2/$3 $4 exit $?
