16 years agoProblem between VCCINT and GND
Hello everyone im working with an EP2C20Q240C8 (Cyclone II). This FPGA is being hand soldered and I have connected the probes of my multimeter between ground and vccint while i'm soldering each pin i...
16 years agoPerhaps you see resistance when board is off because you charge those capacitors while measuring resistance with your tester.
