16 years agoProblem about Programming Serial Configuration Devices In-System Using the JTAG Inte
Hi, I have designed a EP3C16F484C6 board recently. There is a problem about the Programming Serial Configuration Devices In-System Using the JTAG Interface. FPGA can not load the program from...
16 years agoDid you try "0011" on the MSEL pins?
Accoring to the C3 handbook, this should be used with configurations voltage @ 2.5V (see table 9-7 note 2) Success, Ton
