16 years agoPrintf problem
Hi guys i've posted before some problems with sdram and custon nios II platform, finally i was able to solve that issues by searching hard on the internet =/... now i've got another problem, when...
16 years agohi, Julio
could you please tell how you managed to solve your previous problem with DE2 example (nios II)? I try to make a project described in DE2_SYSTEM disk: "...\DE2_tutorialstut_sopc_introduction_verilogDE2.pdf" I have almost the same as you had: after compiling and programming the device in Quartus the "Altera debug client v3.3" says me: "Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: FAILED Leaving target processor paused" i did all as in the tutorial pdf file. tried different versions of NIOS II IDE and Altera Debug Client, didn't work. thanks
