8 years agoPrime Pro Edition : Source files - meaning of folder "tmp-clearbox"; Version Control
In Prime Standard Version, there was a folder "db" and a folder "incremental-db". If there occured problems with Quartus, it often helped to delete this folders and run compilation again. In Prime ...
8 years agoThe qdb folder is the equivalent of the db folder. Delete that if you need to.
As far as revision control, using the project archiving feature is the easiest way to manage it to make sure all files get included.
