bitstreamer
4 years agoPreSICE Avalon calibration
In the user guide ug_arria10_xcvr_phy, section 7.5 there is a recalibration example. Does this work for PLLs that are not connected to transceivers, or is being connected to a transceiver a requireme...
Deshi_Intel
4 years agoHi,
Pls see my comment below.
- Does this work for PLLs that are not connected to transceivers, or is being connected to a transceiver a requirement for PreSICE?
- It still works on PLL that doesn't connect to transceiver which I presume you are referring to fPLL here.
- The PLL does not assert lock on an eval board, but does lock when connected to a transceiver. When not connected to a transceiver, the pll_powerdown pin is controlled via a register.
- I am not sure about your design on your board but byright PLL lock has no dependency on the connected transceiver channel.
- The factor that I can think of that may affect PLL lock are PLL refclk and PLL reset
- When I complete step 3, writing a one to enable calibration - the register clears on write. Is this supposed to happen?
- Yes, it's auto clear as explained in user guide chapter 7.2. Calibration Registers (page 582)
- All calibration enable registers are self-cleared after the calibration process is completed.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/ug_arria10_xcvr_phy.pdf
dlim
bitstreamer
4 years ago1. Not fPLL - ATX.
2. Good to know - but it's definitely not working with those two dependencies. Eval board from Intel.
It just doesn't lock. Any suggestions?
