13 years agopreloader make problem: socfpga_cyclone5_config, Error 2
Hi all, My system: Ubuntu 12.04 64 bit, Quartus 13. SoCrates evaluation board. Being new to soc design I am working through a tutorial. I got the hw source files for the preloader generate...
13 years agovoroshazi: Thanks, I will check that variable. I am running the 13.0 version. It is the full version, but the web version behaved the same way. Before that I tried the 13.0 on Win 7 64 bit. Here make also failed. Here the generated make file had Windows style paths which was incompatible with cygwin!? corrected that manually, but still did not work. Our local distributer says it works on his machine.. but that doesn´t help me much.
