14 years agoPRBS transceiver
Hi, I am using cyclone 4 device and trying to integrate the hard IP transceiver into my design. I would like to have a PRBS pattern generator - verifier which can be enabled/disabled. In case...
14 years agohi Dave:
If you use the IP generated as a PRBS pattern mode datapath with external loopback connection using the megawizard (i.e Cy IV fig 1-74 transceiver arch spec) , do you need to take care of the synchronization/alignment manually or these megawizard generated blocks do everything for you except for connectivity to the pins. thank you
