14 years agoPRBS transceiver
Hi, I am using cyclone 4 device and trying to integrate the hard IP transceiver into my design. I would like to have a PRBS pattern generator - verifier which can be enabled/disabled. In case...
14 years ago --- Quote Start --- Could you post your code as you mentioned. --- Quote End --- Its right next to the PDF: http://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html (http://www.ovro.caltech.edu/%7edwh/correlator/cobra_docs.html) http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial_src.zip Cheers, Dave
