16 years agoPowerup register reset values(again)
This is a quote from a previous post by vjAlter
--- Quote Start --- I just noted Altera posted a new knowledge base article, stating that the register power-up values are not 100% reliable: http://www.altera.com/support/kdb/so...12009_450.html <http://www.altera.com/support/kdb/solutions/rd06112009_450.html> Isn't it a bit too late for issuing such a warning? I know that an external reset is considered good practice. But this is the firt time I see the warning, and I am sure during all these years, many cores were developed relying in the initial register values. A more detailed elaboration of the problem would be nice. In some cases I used the PLL locked signal as an internal power-up reset source. Would be interesting to know if the PLL lock power-up counter is affected or not. --- Quote End --- The fact(now known) that the powerup register values can go wrong if an incoming clk is active during configuration makes it very difficult to rely on internally generated reset. At times we do need to generate reset internally without relying on any input. The reset counter works in practice but who knows it is at the mercy of your incoming clk
