12 years agoPotential Quartus Fitter Issue with Mixed Voltage Pins on Cyclone V
I am working on a Cyclone V design that is utilizing most of the pin resources. In my first pass, I let the fitter automatically assign pins. The issue that kept coming up is that, if not miti...
12 years ago --- Quote Start --- I think you should refer to the Cyclone V datasheet, Table 14. Single-Ended I/O Standards for Cyclone V Devices (Part 1 of 2) It specifies a Vih range of 1.7 to 3.6 V for 2.5V IO-standard. --- Quote End --- Thanks, FvM. Seems like the datasheets are suggesting more flexibility than I originally thought.
