12 years agoPotential Quartus Fitter Issue with Mixed Voltage Pins on Cyclone V
I am working on a Cyclone V design that is utilizing most of the pin resources. In my first pass, I let the fitter automatically assign pins. The issue that kept coming up is that, if not miti...
12 years agoPete,
Thanks! Unfortunately, the latter scenario is the case, and while I've minimized the occurrence of mixed voltage I/O on a single bank, I don't have enough room to eliminate it completely. I actually don't think the datasheet is in error. As you mentioned, with VCCIO=2.5V it can take up to 3.6V, but it is not preferred practice. I have conformed to Table 5-10 even though Quartus doesn't enforce it. I will check with Altera, and post back on this. Thanks again. Bob
