9 years agoPost-Fit Partition Export
Hi
I have a design, using RGMII-MAC on Cyclone-III, Quartus 11.0. I have correctly constrained the PHY ports according to the source synchronous timing (http://www.alteraforum.com/alterawiki.com/uploads/e/ea/source_synchronous_timing.pdf). FPGA is receiver and phase shifts the incoming clock (Case 1). I integrate my MAC in my top level project and it works. Timings are met. When I change my top level design, timing is not met. So I want to lock my working version and export it to my new project, so that my MAC would work fine. What I do: 1- Develop a working project. 2- Set the RGMII-MAC (and its PLL, inside it) as a design partition. 3- Set the RGMII-MAC (and its PLL, inside it) as a logic lock region. 4- Synthesize it again (This also works). 5- Export the RGMII-MAC partition as a .qxp file (Post-fit with routing). 6- Copy the whole project folder. 7- Delete all databases of copied project & all RGMII-MAC source files. 8- Run analysis & Elaboration. 9- Import the .qxp partition into the new project. 10- Synthesize. After synthesis, the MAC does not work correctly. When I look at the chip planner, Placement of the PLL inside my MAC has changed and timings are not met either; i.e. the PLL of my working project is on a different tile from my new project, although I expected to be the same. What's wrong with my procedure? Should I change some Quartus settings? I have SignalTap of my top ports of MAC. Does it make some problem? Thanks1 Reply
No idea? :confused::confused:
