17 years agoporting code from SRAM to SSRAM, bursting confusion
Hi all, I'm trying to port some code which used an SRAM chip on a DE1 board, to use the SSRAM chip on a DE2-70 board. My main concern and confusion is the fact that SSRAM uses bursting. ...
14 years ago --- Quote Start --- I've done some testing, and the SSRAM chip I am using is capable of pipelining arbitrary addresses for reads. Just thought to clear it up. --- Quote End --- Hi kwuaker, It seems this is too old post, but let try.^^. Could you please show me how to control SSRAM to read pipeline arbitrary addresses ? I did tie 3 SSRAM chipselects fixed values (CS_N1, CS_N3 = 1'b0; CS_2 = 1'b1), but it still can not read pipeline, "a single read must be completed first, before new addresses can be supplied" as you mentioned. Khai,
